Results 1 to 3 of 3
Thread: "Best" A/C Compressor
    May 2007
    Oak Forest, Illinois
    As far as the GEN3 A/C compressors go--Which one is the most user friendly as far as port location goes? I know it will be a side port, but is there one that is the best for port configuration/placement for a 88-98 GM truck?
    Jeff
    98 GMC RCSB 2wd, 100% internally stock 305, w/twin T-3 junkyard turbos,Ramjet intake w/42lb inj,12200411 PCM. 4675lbs w/me in it. Best time in 5 passes 13.01@110
    Spiro, Oklahoma
    Forget about using the gen3 compressor w/ an 88-98 frame, its a pain in the a$$. Even after I notched my frame i still ran into problems with being able to connect the hoses and pulling the compressor is a nightmare. Mine took me about an hour to remove. A few people have done it, I thought it would be a good way to save a few bucks but its worth it to buy the up high brackets and get a sanden compressor.
    I'm thinking about going with these brackets.
    LS1 LS2 Sanden Air Conditioner Compressor Bracket
    1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
    May 2007
    Thanks Low 91,
    I think I might try to mount the stock 98 compressor where the Gen3 truck alternator was originally and mount the Alt on the passenger top . That way I could use the stock A/C lines and not need to notch the frame.
    Jeff
