Results 1 to 5 of 5
Thread: 5.3 to 6.0
    Jun 2009
    Encinal/Laredo, Tx
    5.3 to 6.0
    Ok guys I have a 2000 Silverado Z71 that has a 5.3 that is worthless. It has 275k miles on it. So I want to swap a 6.0 in to it. I understand that I can use my existing PCM is this true? how about my wireing harness? and would it bolt right in and to my tranny?
    Thanks,
    Steven
    96 Camaro Z28- 12.2@113 1.7 60'
    2000 Silverado Z71- 6.0 Coming soon
    2000 Yamaha R6
    SA, Texas
    pm sent!
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
    Jun 2009
    Encinal/Laredo, Tx
    thank you. pm replied.
    2000 Yamaha R6
    Feb 2008
    Arizona
    does the PCM and wiring harness works for the 6.0L? cause Ive been thinking about doing that swap also..
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    everything will swap over, you'll just need the pcm tuned which allen nelson can help ya with.
    Simple: 408 on steroids!
    single digits coming soon!
