Looking at some Hoosier DOT drag radials, Wanted to know if you have to install a driveshaft loop to run them at the track? The ones Im looking at could damn near pass for slicks
I can't say for all tracks, but most of them require it, plus it's just a smart idea incase you blow the front u-joint you don't catapult yourself.
Mike
2000 RCSB
'05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
It's not gonna hurt and they're fairly cheap so why not?
If your running at a track that follows any kind of rules then YES. With Drag slicks you need a hoop within 6'' of the front ujoint.
I thought that was only a requirement for slicks?...I have enver been asked about a loop...hmmmm
I think if you're putting any decent amount of power down and racing you should have one, slicks or not.
It's $50 and two hours work at the most. Do it.
jegs/summit
do it... I didnt and i paid for it. Tranny exploided going down the road, twisted the driveshaft in half. The driveshaft ripped my exhaust to pieces. Just a good idea to have one.... After the way mine went down its TWO under there!
2003 RCSS Chevy 5.3L Fully Bolted, Cammed, Yanked, and 342s. Borla Exhaust w/ Electric Cutouts.
