Consider this official... :judge:
I have a few local inquiries about the truck, and it's time for it to go. Maybe I'll miss it, but it's still goin' bye-bye!
SINGLE FAMILY OWNED!!! I have the title (clean)!!!
1986 Chevrolet Silverado (C10)
207,000+ miles on the chasis (but EXTREMELY less on the powertrain)
FACTORY PAINT redone in 1994 due to GM recall. Paint in good shape considering age of vehicle!
'90s model Chevy 454 SS Wheels
275/60/15 Tires (Front 2 are NEW, Rear 2 have ~1,000 miles)
Rear brake shoes replaced in March '09, Front pads are low (Lifetime Autozone pad replacement)
Bed mat to remain in truck
ABSOLUTELY NO RUST, NOR MAJOR BODY DAMAGE! :judge: Contact me for questions/concerns.
5.3L V8 (from a 2005 Silverado)
28,000 miles on motor
Custom (In-Person) PCM Street Tune by Charlie Wheatley (Katy, TX)
**Last 1/4-mile run: mid-13s @ ~100mph**
ARP Rod Bolts
Underdrive pulley
135amp alternator (ACDelco)
Comp 224/224 .580/.580 114lsa camshaft
Comp 7.4 hardened pushrods
Comp 918 springs
Ported & Polished Throttle Body
Modified 862 heads (3-angle valve job, shaved .040)
Autometer electric gauges
HVAC controls work, but needs A/C installed (I have functional compressor)
New Ignition Cylinder
Innovate Motorsports Wideband w/ Innovate gauge
4L65E Transmission (BUILT for High Performance)
Transgo HD-2 shift kit
Aluminum accumulator pistons (both are new)
Beast sun shell kit (w/ thrust washer)
GM 5-pinion planetary
FLT Reverse input drum
FLT Kevlar 2-4 band
Borg Warner 3-4 clutch pack
Borg Warner forward sprag (29-element)
Sonnax 2nd gear servo
Sonnax 4th gear servo
FLT billet output shaft
13-vane trans pump
46-MOD Vacuum Modulator (no electronic pressure control)
Yank Performance SST3200 Torque Converter
Aftermarket Trans Cooler (over twice size of stock aux cooler)'
Aftermarket Deep Pan w/ FUNCTIONAL drain plug
Custom Driveshaft by Margot's of Baton Rouge
Richmond 4.10 gear set
GM 3-series rear carrier (from a '76 Camaro)
$8k... SERIOUS buyers only! Am in NO desperate need to sell! :judge:
I will TRY to get an audio clip of how it sounds, but camera of of no great quality.
Interior (Seat)
Interior (Gauges)
