Results 1 to 10 of 15
Thread: how much more?
    slidelll
    Smile how much more?
    i had the 3.70 pully on
    and i just put on the 3.4
    how much more boost will i gain from this and how safe will it be, before when i had the 3.70 i was making about 8 lbs from what i could read on the gage
    i havnt driven it yet to find out what the increase would be
    also how much can i spray it with out bowing it up?? right now i have a 75 shot on it but i want to step it up to 100
    thanks
    http://www.streetsourcemag.com/ViewOwnerProfile.aspx?ProfileID=39253[/url]
    http://s133.photobucket.com/albums/q...sizerst/truck/
    Oct 2007
    Bandera, TX
    Kinda need some info on your setup.... stock motor... whats your hp goal? the blowing up on anything depends on how hard on it you are...
    single digit street truck
    for build info
    slidelll
    how much boost can the stock pistons handle
    stock botom end
    jba shorty headers
    custom cut cam by futuarl motor sports
    knew rods and lifters
    knew radiator out of an hd
    duall elec. fans
    75 wet shot
    custom tuned
    right know it makes 486
    and i just wanted a little more
    edit i just looked at the dyno sheets and it made 486 on motor and 510 with the nitrous
    slidelll
    i really want to hit the 500hp mark solid
    Canoe rods? =)
    I want you to get some longtubes.
    slidelll
    yea there canoe rods allright
    Quote Originally Posted by FullsizeRST View Post
    Canoe lifters too!
    Oct 2007
    Bandera, TX
    im guessing 5.3? id say you are pushing your luck already. I blew my 4.8 with 10 psi and about 200 miles.... but im pretty hard on my stuff. 500 hp is getting close to the limits imo for reliability.
    for build info
    slidelll
    Its cool man im proud of the new knew and im sticking with it
    also turbomic i was researcing the threads and i read a post when you were thing of doing a pully swap did you put in KNEW injectors??
    slidelll
    nope its a 4.8 so in other words i should keep with the 3.7 to be safe
