Results 1 to 10 of 23
Thread: 315-70-17 tire fitting question?
    Oct 2008
    Crimson Tide
    I have some 17-9 Moro metals and my nittos are worn out there 285-70-17 and I have a 1 inch block & about 3 I inches in front you think I could put a hancook rt03 315-70-17 on there? I would like that.
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    SLP Cat-back (stainless)
    20in HD hoss black and chrome
    78 Chevy longwheelbase,350,holley 600cfm,6inch lift
    35'' swampers. 87 bed,fuel tank,doors.
    Plainfield, IL
    That's a 35"...right now you have a 33".... measure to see if you have an inch of clearance everywhere when you turn. I'm guessing probably not. How did you get 3" in front? If you just cranked the torsions, go ahead and lower those a little, and probably replace ball joints, that's WAY too much.
    Racoon Twp., PA
    +1
    2013 CC 5.3
    81 C10 LS1 project
    Oct 2008
    Crimson Tide
    Cognito leveling & also my 285 measure 33.46 these 315 measure 34.6 so I'm gonna measure. I've seen 315 mounted on stock wheels with my setup I was just wandering.
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    Racoon Twp., PA
    Stock wheels might work, but the offset is gonna be the problem. My 6'' lift rubbed with 35's and a 16x8 american racing whee Guaranteed that was with the bars sagged, which was probably roun 4-5 inches of lift then.
    2013 CC 5.3
    81 C10 LS1 project
    Spring, TX
    I am not sure it is safe to run 315s on stock wheels. Max recommended for stock wheels is 285 which is equal to 11.22 inches. 315 = 12.4 inches. Your wheels are 9 inches so get another set of rims. As far as height, dont try to shove them on. Get a beefier suspension setup.
    EDIT: Its not the height to worry about, its the width.
    '02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
    2013 GMC Acadia: SLT1 Carbon Black
    1976 Corvette Stingray: Trying to save it, progress is slow.
    ^Ricky's Sweet PS Skilz
    09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
    San Antonio
    gonna be a bit too big, and rub really bad
    Let me tell you what Melba Toast is packing here allright............
    new bedford mass.
    i have 305/70/17 on my hoe it rubs alittle when the wheels are crank they measure a true 34 inches the 315 won't work
    Dec 2008
    san antonio TX
    Quote Originally Posted by cjriojas View Post
    +1 315 tires are to big to run on stock wheels, it can be dangerous.
    Greenup, KY
    Quote Originally Posted by lechez71 View Post
    he can run a 12inch wide tire on a 9inch wide wheel with no problems, Ive seen people running 14inch wide tires on 8inch wide rims and never have a problem except wearing the centers out of tires real fast but to each his own.
