Results 1 to 7 of 7
Thread: Help, trans with sudden problem
    Apr 2004
    Ok it's my kids s10 but it has a 4l60e and the p0573 is the solenoid a fault and
    then found fluid bubbly and brown, BUT it only has 68K on this 1996 and 4 banger engine. Any ideas what's up? I don't understand all the agitation of the fluid. Anyone know a good shop in DFW area?
    mostly stock 04 silverado 1500 CC
    Gibson Headers and Sport truck Cat Back
    5.3L 3.73 Detroit True Trac
    165F therm,HpTuner
    07 17" Sierra wheels
    Dark Grey
    Apr 2003
    Mansfield, Texas, USA
    The Cottman in S. Arlington is good, Chris is the owner there. Rock-On up in Denton builds lots of hi-po ones, talk to Dave there.
    Jun 2003
    cottman's. oh no not again.
    04 supercrew 5.4 3 valve-magnaflow catback
    formerly 02denali 12.79@107
    Apr 2004
    ok are you saying not cottmans? Then who?
    165F therm,HpTuner
    Dark Grey
    Apr 2003
    Each Cottman is independently owned, the one up here isn't bad at all.
    Hell the one off Westheimer around the 10000-12000 block in Houston did the AOD in my F150 and the trans in my Mother's LS400... both work great.
    Apr 2004
    well, I dropped the pan, pulled both shift solenoids, both ohm out
    good and both worked fine at 7.5 volts as advertised, replaced
    filter and fluid, codes gone, shifts fine, all OK, So I give as to
    why it was coding, but it had 2-3 gears only before, now it's
    fine, fluid not bubbly, flushed it out again and hope it stays
    fixed. I also checked wiring between trans and pcm.
    165F therm,HpTuner
    Dark Grey
    Apr 2003
    Maybe something was loose?
