The price is way below the other brands which is why i am questioning it. Spectre 9900
yup that will help in hp,just like any othercold air,in my opinion i would just swap the filter to a K-N
cool thanks. question. what makes the other intake brands any different than this one? i guess what im asking is, why are the other brands more expensive than others, if they all do the same thing?
2003 5.3L Avalanche Z66
Engine: K&N Drop-In, FlowMaster Muffler, Taylor ThunderVolt 8.5mm plug wires, NGK iridium plugs
Audio: Pioneer AVIC-F700BT, CDT Audio EF-61FG Component system, Pioneer 6 1/2" Coax, USAmps XT-800-4
Exterior: 20x10 American Racing wheels with 285/50/20 General Grabbers
From what I have seen and read, Spectra is just as good as K&N. They sale them at Autozone. I think they are cheaper, because they are new and are mass produced for the autoparts stores. Heck try it and at a later time just replace the filter with a K&N if you want too. I mean you will have the main part being the tube and heat shield. Now I do not know if anyone else has had the same problem as I have, but I ended up putting a Dry Charger filter over the top of my open K&N cone filter. The water and other nasties that came by the headlight and other truck parts dissolved the oil off the filter. So I added the Dry Charger which is just a really fine nylon mess netting with an elastic band around each end to seal the K&N cone filter. It basically water proofs the filter from the water from getting onto the oily filter. I do not know if you can get a Dry Charger that will fit the Spectra filter, but the Dry Charge comes in different sizes too. Another reason I think the others are higher in price is basically, because you are paying for the name...
2014 GMC Sierra Crew Cab
-5.3
-Gibson Exhaust
yeah get the tube & change to a K&N Filter...the spectre filters fall apart after awhile...only thing i haven't used is the spectre oil kit...idk if it's the same as the k&n or not but spectre filters are trash
4.8 V8 5 Spd. 20" Foose Rims Baer Rotors K&N Intake JBA Shorties ALWAYS more to come!!
http://www.fquick.com/2004rst
Good to know that 2004RST. It could just be a starter filter and like I said you have the main part: tube, heat shield and the rubber connectors...
How do you like the JBA Shorties? Worth the money or would you recommend he LongTubes? Sorry I am not try to highjack the thread, just a simple ? is all.
-5.3
-Gibson Exhaust
I'm cheap too so I bought a smooth transition tube and couplers made by Airaid off eBay for $100 and a K&N drop in.
01CamaroZ28
10.751 @ 124.26 mph with a 1.446 60ft
ALL THRILLS NO FRILLS!!!!
B&L Racing stg 1 heads 224/581 cam.
06 silverado 6.0L VMAX LPP LT's, Volant CAI, Manaflow, NELSON TUNE.
Thats the way I will do it next time since I am married now and really have no Denaros. I have been eyeing an air tube on a package car truck that has a 6L in it. If I can get my hands on it, then I will modify it to work on my parent's Avalanche. I just got to wait for one to be wrecked bad enough to be taken off the road.
-5.3
-Gibson Exhaust
Get an airaid oil less filter.. workes great
03 Silverado Extended Cab with 06 front end, Cai, Road Ripper 2000 Trans
