Results 1 to 8 of 8
Thread: so what is the
    Oct 2008
    Houston, TX
    so what is the
    best airbag complete kit which would be as simple as a bolt on n still be able to drop it 2 the floor
    Airaid, alpine double din,
    bolt-on? Air-ride technoligies.
    newburgh, NY
    Quote Originally Posted by sleeper1500 View Post
    Air ride wont get you to the ground if i remember correctly. If you want to lay frame there is no real kit that I know of. Check out gm fullsize they have a lot of people the have bagged trucks.
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    Mar 2006
    Mesquite
    If you want to bag it, talk to Jon (DBRODS).
    Houston
    if u want to bag it AND do it right DB Rods (jon aka DBRODS)
    Round Rock, TX
    yep, no such thing as a bolt in kit that allows you to lay frame. Alot on fenderwell work and frame work to get in on the ground.
    I only mentioned Air ride tech, because I remember seeing a bolt in kit that included the notch and everything to lay frame in the rear, but there's still something sketchy about pieces of frame just bolted together to me
    Oct 2008
    Houston, TX
    Hey dbrods I seen a sweet setup u did how much for a whole set up my truck is an 01 stepside
