So I've been seriously considering switching from rear mount to front mount turbo, particularly the trick turbo but I'm not sure of a few things.....
1 - Even with an intercooler, what kind of IAT do you see in relation to ambient air temps?
2 - How fast does the front mount spool?
3 - Do you retain every day drivability?
4- Where do you tap into the oil for the turbo's feed and return lines?
5 - Will I see an improvement on my 60' running about the same amount of boost?
6 - About how much power per # of boost will I see?
I could use some good advice, answers and suggestions. Thanks in advance
