Results 1 to 8 of 8
Thread: Longtube header choice
    Feb 2009
    VA
    whats my best bet for picking a set that will fit really good on a 2006 5.3 4x4? I like the new LPP's but i read the problems with the Y pipe hitting the driveshaft, and the drivers side header hitting the steering shaft. The pacesetters seem to have really crappy coating not sure on fitment. Haven't found much on the OBX lt's, they fit good? i see they are stainless. I also thought i saw some mention the Tri Y from thorley but according to what i looked at they only make shorties.
    SO what is my best bet on what to go with?
    2006 silverado 4wd w/5.3 and 4.10's
    -blackbear 91/93 tune
    -Pacesetter LT's
    -flowmaster
    -trueflow air filter
    Wish list: Comp XR265HR or XR259HR cam, Vig 2800
    Jun 2007
    I love my pacesetters,fit nice ,look good and i live in the north .the only place they actually peeld any was were i had the header wrap on underneath.idk y tho.Im thinking too much heat or moisture held in.they went in easy and no fitting problems.
    Ft worth tx
    I got obx's on mine and could not be happier. The band clamps suck that came with them, and your going to need some metal zip ties to tie up two of the plug wires on the driver's side. The fitment is great and other than the plug wires they don't touch anywhere.
    2004 Gmc VHO (LQ9), AEM cai, perma cool e-fans, aero turbine 3535,obx lt's,undedrive pulley w/overdrive alt pulley, lingenfelter 160 t-stat, zippy tune, taylor 10.4mm wires, tb bypass, Transgo HD-2 c, corvette servos, sonnax accumulator piston's,2600 stall,30,000 trans cooler lowered 1.5"/2", boss 313 22's on 285/45's, rollpan,shaved tailgate w/ss spoiler, painted interior, 2 solo l7 12's,custom fiberglass box,Pioneer F-900 Navi,SSS gauges,billet shiter and pedals,hid's (low's and fogs).
    Feb 2009
    VA
    ^ so the plug wire's coming in contact i just read about is easy to prevent?
    -Pacesetter LT's
    -flowmaster
    Jan 2007
    Burleson,TX
    dynatech are a little more expensive but i love them
    06 silverado CC Volant CAI/ Corsa Sport exhaust
    dynatech supermaxx headers/cats
    LPE GT2-3 cam/ Comp 918's/ Rods
    Eaton LSD 3.73's
    IAT Shocks
    DANNY TRANNY w/2800 TCS billet verter
    275HP and 293TQ Pre Cam
    314HP and 303TQ post cam
    Brandy Station Va
    I just installed my pace setters today with the ory. The only fitment issue i had was with one of the primaries hitting on my front yoke just had to dent that a little bit and some the plug wires rest on some of the primaries.
    Jun 2007
    hum ,never heard of that,primary hitting the d/s yolk
    Ft worth tx
    Quote Originally Posted by Jeteys5pt3 View Post
    it's real easy to prevent just need some metal zip ties, and some heat sleeves cost me 30 bucks at the auto store.
