Results 1 to 10 of 13
Thread: Larger injectors for truck intake?
    Apr 2003
    Mansfield, Texas, USA
    Well I could get a set of Racetronix 42lbs/hrs for about $330 new and those are rated at a higher FP than the Bosch/Ford style green 42lbs/hr that are rated at a lower pressure. Those are about $330 new also. Leads me to suspect the Bosch/Ford flow more...but I dont' need an injector that will support 650rwhp! lol
    Obviously I don't need these for a long while until that larger motor appears in the truck so would it be smarter to convert to the regular harness and go with some 30lbs red top Ford injectors to support my cam and bolt ons?
    Maybe those 8.1 injectors would be a nice medium for me?
    Dec 2003
    I believe those 8.1 non-marine are 30 #ers...and no wiring changes
    2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
    Apr 2003
    Yeah, that's what I was thinking they were. Any ideas how much HP they can support?
    How much more do the Marine 8.1 injectors flow and any idea on their pricing?
    Dec 2003
    The marine 8.1 injectors are the 43 pounders from what I understand. These are the ones used on most supercharger applications, so these are capable of LOTS of horsepower. They come with the radix and these are the ones a lot of guys with the whipples and prochargers upgrade to.
    http://www.racetronix.com/Injector_17113739.html
    The homepage lists them as 42 pounders and the page above lists them as 44 pounders??? They have them also at Arizona Speed & Marine.
    Apr 2003
    Yeah, I looked about and found that set from Racetronix from Thunder Racing for ~$330 new.
    Looks like I may just go that way. They should support pretty much anything, but if they are too large...wouldn't they be hard to control at idle?
    I recall used 8.1s (non Marine) sell for like $200 usually... hell, a few dollars more and I have new direct fit injectors.
    Dec 2003
    If you're planning on more than 400 horsepower na at the flywheel, the 42 pounders would probably be the way to go. If tune correctly, they won't be a problem at idle. This downloadable program has some injector sizing help.... http://www.virtualengine2000.com/
    It's would be much easier for direct replacements than cutting and splicing!! Those 42 pounders are what I had when I had a ProCharger. I ended up selling it when my wife was having job difficulties for some extra money. I ran the 42 pounders for a week before I got a new tune without the ProCharger and had no problems at low rpms. I kept out of the upper rpms since it was programmed to account for all of that extra air! Swapping them out was extremely simple.
    Apr 2003
    Sweet, looks like that's what I'll do. The more I've looked it seems that it's not practical to swap to an LS6 intake as the gains are minimal.
    San Antonio, TX
    You may have more injector than you think, those stock ones are good for lots of power, sometimes going to a large injector is overrated, I tuned a '99 ec silvy with a 150 dry shot that made 335 to the wheels and the injectors kept up just fine, sure they were maxing out, but that gives you an idea on how much you have. The 99's have 19lb injectors.
    400hp to the wheels is a shit load of power! it takes lots of boltons to get there.
    later,
    allen
    Dec 2003
    Doesn't it mean the injector stays open all of the time when it reaches 100% duty cycle?? Kind of sounds like an "afterburner" fuel dump and there isn't any way for the computer to control the amount of fuel coming in.
    Apr 2003
    Well usually over about 85% IDC injectors get weird and hard to control from what I understand.
    Once you're at 100%, they're wide open... kinda sorta like valve float.
