Ok, so it will be a slow process but it starts now.
Solid Axle swapping the 1999 Silverado
There is a lot that needs to be researched and looked at before you start. There is a lists of things that will and will not work. I will try my best to document this through pictures and write up.
I will be doing a leaf sprung swap.
Brackets: Off-Road Direct - Lift Kit and Custom Suspension System Specialists
Springs: 73-87 1/2 ton Chevy
*Brackets give 3'' of lift, so I will be using 4'' springs for a total of 7'' of lift*
Axles: Dana 44 HD Front w/4.10 from a 1976 F250 8 bolt
Dana 60 Rear w/4.10 from 1976 F250 8 bolt
*Reason for Ford axles is the need of a drivers side drop*
Yes, need gone over and cleaned.
Transfercase: NP241 from a 1989-1998 k1500 with a 60E manual 4x4
*This transfercase is needed for the fact that it has a fixed yoke for the front drive shaft along with a electronic VSS and does not have auto trac. The transfer case is manual engagement so fabing will need to be done and the VSS wires will need to be splice to the new sensor*
Steering: Crossover Steering Required! Kits available or you can attempt to make.
* I will be purchasing the pitman arm, but using the drag link from a K-5 Blazer. Friend is a machinist so the arm for the right knuckle will be made.*
Brake lines: Extended Lines Required!!
*Purchasing locally*
**Again, this is just the start, I will gather and post as much info as I can throughout. Today 5/1/2009, the transfercase will be installed and wired**
