stock gauges
Hi everyone,
I have a 93 ext cab started with a tbi 4.3 where i swapped a 5.7 tbi and now it has a 2002 6.0 with a 98' 4l60e.
The engines running and truck will drive just have a few things to work out with the driveshaft.
Other than that I need help wiring or tapping in for my stock gauges.
Will the stock oil psi gauge work off the signal from the 6.0
I figure the temp i can just put the original temp sensor somewhere in the cooling system to read temp.
Voltage gauge already works
RPM have no clue...I know which wire is off the ecm for signal, thats about it
And speedometer...could I just tap my old vss wires into the new harness. unless they work under different signal.
I redid my own harness for the engine so I shouldn't have a prob if i could just get a little help
Thanks
- You may not post replies
- You may not edit your posts
