Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 60
Thread: My progress pics - LS1 intake/cam and Corvette acc swap
    Monticello, MN
    I started the tear down last night on my truck. I am replacing the truck intake, camshaft, and front drive accessories with the LS1 intake/camshaft and Corvette accessories. I have about 4 hours into it so far. I hope to get the cam swapped out tonight and start reassembling. Here are some pics.
    I think this swap would be a lot easier if I had more room to work with like the full size trucks
    Started with this
    Draining the coolant - actually surprised that I didn't make a mess on the floor this time.
    Radiator support removed
    Front drive accessories removed
    Coil packs removed - it was a lot of fun trying to get the rear coil pack stud out from the valve cover.
    Some of the new parts waiting to go in
    1993 S10 - 5.3L, LS1 cam/intake, 4L65e
    1971 - GM 350 HO/TCI TH350
    Looking good.
    Aug 2004
    Magnolia, TX
    cool project, keep us updated
    Richardson
    Neat swap.....what are the spec's on the cam your installing...?
    2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
    are those 69' vette rims
    McAlester,OK
    sweet!
    Quote Originally Posted by DINK View Post
    sweet!
    dude!!!
    whats mine say?
    Your Moms House
    dude!!!
    whats mine say?
    ^^^^YOUR GHEY^^^^
    Nice truck man wish I could pull the front of mine and have all that room.
    Monticello, MN
    I believe they are, I bought the complete set off eBay with the beauty rings and center caps for less than $400. I put 15x9's in the rear and 15x8's in the front.
    Quote Originally Posted by Fastime09 View Post
    It's a '00 LS1 cam with .500 lift. It won't be anything radical but its a cheap upgrade and there should be a little performance over the stock cam according to Allen at Nelson Perf. Since I am replacing the front drive accessories, I couldn't pass up a $30 cam upgrade for a little increase in performance. Eventually I will get a good cam combo in there. I also got a tune from Nelson Performance
    awesome!
