Results 1 to 10 of 19
Thread: Transfer Case
    Austin, TX
    Transfer Case
    Selling an Autotrac 4wd transfer case out of my 01 1500 Z71. Removed because I converted the truck to two wheel drive. Comes with harness and if you want control module and push button switch from dash. $500 OBO. Need to pay for the 4L65 I built.
    5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
    _____________________________________
    2006 2500HD 6.0L Crew Cab 2WD
    College Station, TX
    If I were to convert to Auto-trac instead of my T-case so I could do 4wd launches can I use this on my 06 even though its older?
    Aggie if you have a manual shift TC there is a lot to make this NP8 (apparently) work. You need the TCCM, the wiring harness (either spliced in or a new complete harness for an NP8 set up) as well as a tune that will recognize the NP8. There is no benefit in a racing application to this swap although this TC is a neato piece and an OK deal. You can pull a lever from 4HI to 2HI as easy as you can push a button and with the manual lever you know it moves to 2HI whereas an NP8 has to do it electrically. The NP8 does have the AUTO setting but that's more of a front/rear posi for ice, snow, mud, rain. This is a good deal but it's more in line for someone that needs another NP8, not really a swap from something else deal unless you are industrious.
    Then again, if this is not an NP8 then the OP needs to edit and so do I
    Austin, TX
    Does this help you?
    GM Vehicle Inquiry System
    Vehicle Build
    Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
    Help
    VIN 1GCEK19T11E179558
    VEHICLE BUILD
    Merchandising Model : CK15753 -2001 SILVERADO LS 1500 4WD EXT CAB
    Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : CTSN2J
    Build Date : 10/24/2000 Build Plant : 11E53
    GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
    OPTION CODES
    AE7 - 40/20/20 SPLIT BENCH SEAT WITH 6-WAY POWER AND FRONT LEATHER SEATING SURFACES AG1 - SIX-WAY POWER DRIVER SEAT
    AG2 - 6-WAY POWER DRIVER & PASS SEATS AJ1 - DEEP TINTED GLASS
    AM7 - FOLDING REAR SEAT AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
    AU3 - POWER DOOR LOCK SYSTEM A31 - POWER WINDOWS
    B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
    B33 - REAR COLOR KEYED FLOOR MATS B71 - WHEEL OPENING FLARES
    B85 - BRIGHT BODY SIDE MOLDINGS C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM
    C7H - 6,400 LB GVW RATING DF5 - INT R/V MIRROR, LIGHT SENSITIVE W/OUTSIDE TEMP & COMPASS
    DK7 - INTERIOR CUSTOM ROOF CONSOLE D48 - ELECTRIC EXTERIOR MIRRORS
    EVA - EVAP EMISSION REQUIREMENT E63 - FLEETSIDE BODY
    FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS FK2 - TORSION BAR SPRING ADJUSTMENT
    FK3 - TORSION BAR SPRING ADJUSTMENT GMC - ASSEMBLY PLANT-PONTIAC EAST
    GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING DIFFERENTIAL-REAR AXLE
    JC5 - 4 WHEEL POWER DISC BRAKES KNP - HD AUX TRANSMISSION COOLING SYS
    K34 - ELECTRONIC SPEED CONTROL K47 - HIGH CAPACITY AIR CLEANER
    K68 - 105 AMP DELCOTRON GENERATOR LM7 - VORTEC 5300 V8 SFI GAS ENGINE
    M30 - 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE NF2 - FEDERAL EMISSION SYSTEM
    NP5 - LEATHER WRAPPED STEERING WHEEL NP8 - AUTOTRAC ACTIVE TRANSFER CASE
    NZZ - OFF-ROAD SKID PLATE PACKAGE PF9 - CAST ALUMINUM WHEELS
    QGD - P265/75R16-114S ALT WOL TIRES SLM - STOCK ORDERS
    T96 - FRONT FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER & ATC
    UQ3 - ENHANCED AUDIO SPEAKERS UY7 - HD 7-LEAD TRAIL. WIRING HARNESS
    VB3 - CHROME REAR STEP BUMPER VG3 - FRONT DELUXE CHROMED BUMPER
    VR4 - WEIGHT DISTRIB. PLATFORM HITCH VXS - COMPLETE VEHICLE LABEL
    V22 - DELUXE FRONT APPEARANCE PKG. V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
    XGD - P265/75R16-114S ALT WOL TIRES X88 - CHEVROLET CONVERSION
    YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD6 - BASE REAR SPRING
    YE9 - SILVERADO YGD - P265/75R16-114S ALT WOL TIRES
    ZGD - P265/75R16-114S ALT WOL TIRES ZY1 - SOLID PAINT
    Z71 - OFF-ROAD SUSPENSION PACKAGE WITH RIDE CONTROL INCLUDES: * SKID PLATES * HIGH CAPACITY AIR CLEANER Z82 - TRAILERING SPECIAL EQUIPMENT INCLUDES: * TRAILER HITCH PLATFORM * 8-WIRE TRAILER HARNESS * TRANSMISSION OIL COOLER
    1SB - LS DECOR INCLUDES: * AIR CONDITIONING W/AIR FILTRATION SYSTEM * DUAL POWER MIRRORS * AM/FM STEREO W/CD PLAYER * CHROME GRILLE & CHROME STEEL WHEELS * ELECTRONIC SPEED CONTROL * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * LEATHER WRAPPED STEERING WHL * BODY SIDE MOLDINGS * 40/20/40 SEATING W/RECLINE AND ARMREST STORAGE 1SZ - EQUIPMENT SAVINGS *MANUAL TRANSMISSION DISCOUNT *V6 ENGINE DISCOUNT
    47U - FOREST GREEN METALLIC 52D - TAN - CUSTOM CLOTH
    52I - TAN INTERIOR TRIM 6YK - COMPONENT FRT LH COMPUTER SEL
    7YK - COMPONENT FRT RH COMPUTER SEL
    © 1998-2005 General Motors Corporation. All Rights Reserved.
    NP8 like I thought. Takes a lot of work to swap this in place of the manual shift T/C.
    Feb 2005
    San Antonio Tx
    how many miles are on it? been abused much?
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
    Bump
    Wasilla, AK
    Bump for a good deal, these things are over $1200 new at the dealer, and that might even be a reman, I don't remember.
    2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
    Austin, TX
    100,000 just pulled it out last week to install my built 4L65E that I converted from my truck. No problems at all with it.
    At least you don't have to walk far to punch your warranty RO's.
    TTT for a good deal.
