Results 1 to 10 of 18
Thread: broke another ouptut shaft
    So Cal
    so this is the 2nd output shaft ive broken and DMC transmissions has a warrenty so its not like i have to pay anything but turns out i was running 90 psi in 1st gear on the billet servo and now im only running 81 which i guess is regulation....this all sound correct?
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Jun 2007
    I had the same issue over and over ,then i sprung for the billet output shaft and havent had an issue since.I also broke a few input shafts.these trucks put alot of stress on these trannies.psi sounds kinda low if you ask me.Ive had it all the way up to 160 b4 and yes 160s high.
    I have never seen one broken ever in person. How you people do this....LOL.
    Winnipeg, Manitoba, Canada
    I'll ship you a bunch if ya want LOL
    sucks to hear but get used to it unless you spring for a billet one, and even then I have a few of those kicking around
    I'm not saying it's uncommon just that I haven't had one yet.
    So Cal
    holy crap 160!!!! wow how was that shift like? wow at 90 psi i could cherp the tires at around 4grand damn that must be a hard shift though
    Jun 2007
    Teeth chattering
    Jun 2004
    george west texas
    Quote Originally Posted by DAmarcus28 View Post
    thats why they are breaking...hard shifts...
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Santa Paula, CA
    hey marc...lets run em already
    Quote Originally Posted by sleeper1500 View Post
    Done took 'er down to the Pep Boys an pimped it out.
    03 silverado 5.3L
    H.I.D's, 40 series Flow dumped , CAI, 2in Shackles
    03 Tahoe- C.A.I, magnaflow, h.i.d's...more to come
    Quote Originally Posted by bud8fan View Post
    Yuppers. That'll do it every time. Keep the pressures stock. If you want firmer shifts, get a shift kit.
    Low 80 psi is a good number to stick with.
