Results 1 to 10 of 12
Thread: Texas Mile
    Feb 2008
    Gainesville, Fl
    Texas Mile
    Hey guys,
    Well I am planning on taking my truck to the texas mile so i should have a few months since the event just happened. I was wondering if you guys had any opinions, on how to get my truck down that mile fastest as possible N/A i will maybe use a shot of nos but thats it no turbo or S/C.
    I was wondering was gear ratio you guys would use. I have 3:42 in right now and i was going to keep it that way probaly. I also know i need to get a better fuel pump installed any opinions on which one?
    Another thing i was thinking about was a roll bar. I dont know where would be this best to install it? I have seen roll bars installed inside the cab and also installed right behind the cab in the bed. What do you guys think?
    Please recommend any other opinions to me if you have them!!
    Thanks alot guys,
    Brandon
    P.S. What potential speed do you think i can reach with my truck in sig?
    04 Silverado RCSB
    02 LS1 Shortblock(Stock)
    LS6 CAM - 204/219 .551/.548 117.5
    243 Heads w/ Light Weight Valves
    Exhast- LT Pacesetters w/ory, 3" Straight pipe
    Suspension- DJM 4/6, Doetsch Shocks, Caltracs
    Need a ported DBW TB > http://www.ls1truck.com/forums/sale-...ale-trade.html
    Nov 2006
    Mesquite, TX
    you will only get to about 130-145 tops....your gearing is fine with a 31" tire you will be able to go 160+ you will need a big shot of nitrous...your best bet is use the nitrous to get it going as fast as you can and then just use the nitrous for a couple of small burst in 3rd gear in the higher rpms to get it moving
    Feb 2008
    Gainesville, Fl
    I forgot to mention that i will be doing a Cam/Heads swap and will also have cutouts for sure. No opinions on the roll bar placement?
    04 Silverado RCSB
    Nov 2006
    Mesquite, TX
    yeah still 140's...it takes a lot to get it moving against that wind.....roll bar you only need a 4 point out there....keep it in the cab
    Mar 2006
    Mesquite
    You have to run a roll bar?
    Richardson
    If you want handling, the best thing i did was the rear sway bar, Even just changing lanes. I shock of the difference it made.
    2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
    Nov 2006
    Mesquite, TX
    no you wont have to...they made Ricky because he was going over 200mph...the tech is pretty loose just make sure you got good tires and a fire extinguisher
    Feb 2008
    Gainesville, Fl
    Yes i know i dont need a roll bar i justwant one i already feel like i drive my truck reckless so it will be insurance to me
    Yea i dont expect to go super fast my goal was 160's id be happy with that.
    Do you guys think that the 3:42 gears will do or should i go lower(3:23) or higher(3:73)?
    04 Silverado RCSB
    Quote Originally Posted by mean05 View Post
    Yep My truck goes 200 mph
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by LS6_Silverado View Post
    stay with the 3.42's and you need to make in the 600's to go 160mph
