Wow ,my 14 bolt came out of a mid 90s heavy half and it was only 2 inches narrower.But what made up the diff was the way the drums sat ,they were out further so it ended up sitting perfectly the way the old rearend sat.They were like built in spacers,the hubs extended out an inch on each side .check it out you might have the same deal,and if thats the case only 3/4 on each side u might not even notice ,and have no clearance issues at all on the inside.I even have airbags on the outside of my frame and they dont hit.good luck.
