Results 1 to 2 of 2
Thread: 1990 Nissan 240sx
    Feb 2009
    1990 Nissan 240sx
    Okay, i'm pretty much just gonna copy a thread over from one fo the 70,000 other forums i'm a member of, but here's my s13 hatch - I call her Delilah.
    • Car: 1990 Nissan 240sx Hatch
      Engine: 2005 5.3 liter LM7 ~ 18k miles
      Trans: T56 6speed
      Wiring/ECU Tune: Will be done by myself
      Mounts: Me too...
      Fuel:I'm keeping the DBW & running a hybrid vette/truck setup
      Cooling:CXRacing aluminum radiator
      Lubrication:Ported LS6 Oil pump/LS2 GTO oil pan setup
      Driveline: Driveshaft made local for cheap (approx. $100)/possibly J30 diff.
    complete power steering pump assembly w/ bracket I got on ls1tech for $50.
    Here's my t56, nothing special you've all seen em.
    Notice the short stick? It was custom made by a guy on LS1tech who's an engineer.
    I also decided to get rid of the stupid tweed on the doors, something i can do in the house since it's so cold outside & in the garage.
    I picked up an OE clutch, pressure plate, & flywheel this week for $30. No pics tho, UPS is being slow.
    test fitting the gauge pod and some of the gauges
    new badge/emblem
    pedals installed
    radiator
    fuel system/fittings
    Daft CMC
    Feb 2009
    drivers side mount location (both sides are still too far forward obviously)
    passenger mount location
    distance between block & firewall
    and the shifter location is near perfect in this position
