Results 1 to 10 of 11
Thread: Tranny cooler..??
    Feb 2008
    Arizona
    Tranny cooler..??
    Is this tranny cooler better than the 40,000GVW that tru-cool sells?
    eBay Motors: Perma-Cool 12311 Oil Cooler, 10 1/2"x14"x3 3/4", 10"Fan (item 220367009657 end time Mar-24-09 23:35:57 PDT)
    Wondering because the guy installing my cam and stall has one, but it doesnt say how much GVW or anything..
    Thanks
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Spring, Texas
    The nice thing about that one is that it has a fan built in which helps a lot if you are sitting in the staging lanes or heavy traffic. The other good thing about it is that you can put it anywhere due to the fan. It doesn't look near as big as the 40k but it's prob around the mid 20k range.
    forget that when you can get the 40,000 for 118$
    Feb 2008
    Arizona
    where at man?
    Spring, Texas
    Sep 2006
    i got the one with NO external bypass, you only need that if you live way up north, with our texas winters it is useless.. plus i have read of people having issues with the bypass one...
    by the way you'll like that 40k cooler..
    01 ECSB 2WD
    cammed 6.0
    12.32 @108mph N/A
    11.7@114mph 125shot
    Quote Originally Posted by ap2002 View Post
    same one i got
    Feb 2008
    Arizona
    I just ordered mine $143 total 3 day shipping
    Dec 2008
    La Porte TX
    I am ordering the same one next week
    5.3, small cam, 918 springs, 7.4 rods, walboro pump, Full built 4l60, 2800-3000 stall, TB spacer, long tubes, cat delete, single 3" exhaust with Aero bullit muffler. Flaco tuned.
