Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 41
Thread: HP tuners for duramax
    Houston
    Wondering if anybody on here has experience tuning a duramax, been trying to look up the proper way to do stuff (like timing and extra boost) looking for a 80-100hp tune, truck should run pretty good with that, exhaust, and intake, ive messed around just a little bit but cant afford to blow this thing up
    cody on here does. 01slowz71
    newburgh, NY
    Yep I just started tuning my dad LB7 with it.
    Houston
    how do you change ur boost tables? theres different ways buy multiplying or adding and it changes the whole graph, and i know that 32psi is suposed to be the best boost for these trucks but dont know how my graph should look.
    newburgh, NY
    Which engine is it? LB7 are set by waste gates and lly, lbz, lmm are variable vain turbos. try this it may help The 20-20 Tow Tune, a tutorial: - Duramax Diesels Forum
    Its for efi live but the tables should be about the same. I have a banks big head and i am seeing 30 psi of boost.
    Houston
    cool thanks for the info
    spring, texas
    Quote Originally Posted by 408.Luke View Post
    When your in Houston. Look me up. I have tuned "a Few" DMAX'S in my time. I use HP. I 'll give ya hand if you need it.
    2009 YUKON DENALI,BLACK ON BLACK, LS3, Dynomax 4" cat-back, VARA-RAM INTAKE, KOOKS LT's, MSD IGNITION, LS VVT hot cam, ZO6 springs, HP tuned to 421awhp, 12.54 at 108mph on 24's.TUNING FROM THE DARKSIDE.
    06 KAWI BRUTE FORCE 916cc 6.80's in the 1/8th. ALL MOTOR. New found drug addiction is getting "HER" into the 5's. "EVER HAD A QUAD TAKE YOUR MONEY?"
    Houston
    That would be awesome!!! I will be home a week from today and have no work for two weeks, if you could let me know a good time that would be great!!
    newburgh, NY
    Just be careful you will be surprised on how little changes effect these engines, the new found power has addicting qualities to it I just started on the dads it's hard to restrain my self from going to far they just respond so well to tuning.
    Houston
    cant wait! but i will have to be cearful for sure its not paid for and its my daily but ive heard 80hp tunes are pretty safe so hopefully i can get into 13's idk what it takes to do that but im hopeing for that
