Here is something that you don't see to often - a product's price has gone down! The regular price for Baer's front Eradispeed rotors (2301028) has dropped by close to $200. They are now $479.99. This will be good through the beginning of November. It will then go back up to the usually $664.99 . But... here is something even better - we have other discounts available for all of the Eradispeed rotors as well of the complete Baer brake packages.
A little info about the Eradispeeds -
These performance rotors feature LITE™ (Low Inertia / Thermally Efficient) technology. Two piece rotors have anodized billet aluminum hats with re-useable stainless N.A.S. aircraft hardware. Designed specifically for use with popular 18-22-inch wheels, EradiSpeed+1's feature massive 14" diameter rotors front and rear, along with all the custom hardware to make installation quick and easy. EradiSpeed+1 rotors are also "cosmetically enhanced" with cross-drilled, slotted and zinc washed surfaces.
Cast from a high friction iron alloy, EradiSpeed+1 rotors are designed with more mass for heat absorption, are directionally ventilated for increased pumping efficiency and feature billet or forged aluminum centers, which reduce overall rotor weight. By eliminating the weight at the center of the stock iron rotor, Baer is able to cast the rotor with more mass in the "fire path," (where the pads contact the rotor,) allowing substantially more heat to be absorbed into the rotor. Balancing and heat-treating, coupled with the increased pumping efficiency of directional vanes (vents), ensure that EradiSpeed+1 rotors deliver substantial performance benefits.
Many of today's vehicles using larger wheels experience drastic reductions in braking ability due to the additional weight of the wheel...sometimes up to 35 pounds per wheel. With its larger rotor size, EradiSpeed+1 rotors are able to regain even more than the original braking performance. Best of all there is no need to bleed the system after installation.
Just give us a call or e-mail for pricing! This also applies to the new Alumasport brake packages -
- You may not post replies
- You may not edit your posts
