Results 1 to 10 of 22
Thread: Stroke an LS3?
    Jul 2006
    College Station, TX
    Stroke an LS3?
    What is the maximum stroke that can be achieved in the ls3? is it 4" or 4.1"? If it is stroked what will be the displacement?
    2004 EXC Silverado 6.2L
    Mods:
    6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
    4= 416 4.1= 427... A 4.1 stroke in an LS3/L92 is a joke... so maximum is 4 stroke
    Jun 2007
    y is it a joke ?just curious your opinion.
    Aug 2004
    Magnolia, TX
    Quote Originally Posted by Ramsey View Post
    knock, knock...boom?
    Stroke is to long... LS3/L92 427's have major oiling issues. I had a 418 and in no way would I go with a bigger stroke on it...
    Jun 2007
    Thanks good to know.Im researching into some big cubes ,whats the best motor out theyre or youve seen/researched.cus wen i do it i want the best.ive actually heard of a 456 s/b ls based or something like that,of course it a diff kinda block.
    Houston
    lsx block can go into 500 cubes i think 511 max, i would never go that high, 454 would be the bigest i would but a 427 is good cus of the shorter stroke imo
    Jun 2007
    Ive just heard more than once 427 isnt a good idea.
    427 LSX is a great idea if you have the cash! I'm going to a 403... 4"stroke crank and 4.005 bore. A LS3/L92 418 is a good motor, just wouldn't go with the 4.1" stroke with that block IMO. You are boosted Ramsey so a 402 LQ4-9/LS2/408 LQ4-9/LSX427 would be nice!
    Jun 2007
    I guess ill start looking into the 427 lsx then.Ill see what i can look up on em.thanks kurt.
