Results 1 to 3 of 3
Thread: 98 4.3 Vortech to 97 5.7 Vortech Wiring Problems
    Hi,
    I put a 97 Vortech 5.7 into my 98 Chevy 1500 2WD. I used the wiring harness and the computer from the 97 truck. My truck runs ok, but the gauges won't work, and the horn goes off when I push the brake pedal.
    What is the difference in the wiring harnesses between the years, and can I get an adaptor kit that will fix the problems?
    Thanks for the help and advice!
    Skervydog
    There's a ground issue in the dash. The horn operates by completing a ground circuit in the column.
    San Antonio
    Hey 'dog, did you get this figured out?
    1996 GMC Sierra RCSB
    4.3L V6 - 4L60E - 15" stock aluminums - 3.42s - slow weekend warrior
    2004 Chevy Tahoe LT
    5.3L V8 - 4L60E - 17" stock aluminums - 3.73s - less slow daily driver
