Results 1 to 10 of 12
Thread: Help with stall...
    Feb 2009
    East Texas
    Help with stall...
    Ok, this is for a buddy of mine. We just installed a g5x2 cam, 232/240 Duration, 595/608 Lift on a 112lsa, and was wanting a little advice on a stall to run. He still wanting to drive it daily and he pulls stuff pretty often. Its got a 2100 or so stall in it now when a built RPM trans, 3.73's w/ trutrac, and other little goodies... Just wanted to see what size stall he needs to look into.
    thanks
    justin
    Daily:
    2000 Z71 Tahoe... LPP LT's, O/R Y, 14" magnaflow, TB spacer, MAC CAI, 05 fans, Comp 218/222 .564/.566 112 lsa, Z06 springs, TB stall, and BB tune!
    Project:
    02 GMC ext cab, 5.3, comp 218/222 112lsa, comp 918's, and a few other goodies, bagged and bodydropped on 24's!
    Mar 2006
    Mesquite
    3200 IMO...
    Precision Industries, Circle D, or Yank...I would go with one of the first two.
    Dec 2008
    Del Rio, TX
    +1 I would say at the least a 3000. Circle D
    1993 Gmc 02 ls1 Circle D 3400 stall, long tubes, 220/224 cam stage 3 heads, weiand intake, auburn posi, 389rwhp 352ft/lbs
    Feb 2009
    East Texas
    will be getting a precision one im sure... we called the other day and was kinda pricing some. Just didnt want to order something without kinda knowing what we need. I told him somewhere around 3500 should be plenty.
    Daily:
    Project:
    San Antonio, TX
    a big converter, that cam and towing don't really go together.
    compliment the cam with the correct converter or it won't run to its fullest potential.
    i'd say in a truck, go with at least a 3800rpm stall converter.
    keep in mind that truck isn't going to make any torque downlow, so a 3000stall isn't going to slip that high.
    a 3800 will get that truck about 3500rpms or so, which is just right.
    if you don't care about towing, get a 4000stall converter.
    Winnipeg, Manitoba, Canada
    x2, your are going to need a good set of gears and a fairly big converter to move out on a cam like that.
    That's no tow cam. To make that cam work you need a lot of converter (3500 minimum and 4000 preferred) and a lot more gear than a half ton usually comes with...although some came with 4.10's even that is a minimum. Hope there are a lot of other supporting mods too like ported heads, higher compression or turbo/blower, weight reduction, etc.
    Feb 2009
    East Texas
    There will be supporting mods... Heads are coming next. This cam was in a car with a 3600 stall and no freaking tune and ran a 11.8. Kinda crazy! But i kinda had a feeling for about a 3500 rpm stall or so.
    thanks for all the help guys!
    Daily:
    Project:
    Pittsburgh, PA
    4k stall with 456 gears
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Sep 2004
    Breaux Bridge, LA
    haha! supporting mods or not he's going to need at least a 3800. have fun pulling with that combination!
    better have a 50k gvw tranny cooler and a spare gas tank.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
