Results 1 to 7 of 7
Thread: How to change injectors?
    Las Cruces, NM
    I got my injectors today. First time messing with injectors. Any good write ups or tips which can make them changing them out easeir.Any special tools and do i have to remove the whipple can please help going to start changing them out tomorow.
    Also got the nelson tune hope its good.
    Wanderer Racing
    2002 Sierra Denali: iron 5.7,cam,243 heads port,headers , true duals, AWD, 42injectors, Nelson Tune, snow performance stage 3,100 Shot of nos, 3200 circle d
    which injectors did you get? 42lb or 60lb? If its 42lb you can just remove the fuel rail and place the new ones in with the Orings. Should take about 10-15min?
    Las Cruces, NM
    yea there 42 so do i even have to remove the fuel rail all the way off. its because the whipple is right on the top of the injectors so no write ups.
    Wanderer Racing
    Aug 2005
    St. Anthony, Indiana
    pull the fuel rails, remove old injectors, put a little vaseline on the new orings and install in reverse order.
    yeah just pull the rails, unless the whipple wont let you
    Waco, TX
    a torch and vise grips!
    Yeah all that and unplug them 1st as well as disconnecting the fuel lines.
    Now if you're talking Duramaz injectors you'll need my phone number
