hey man, your truck is stuck on that rock.
nice truck whats she got in her
06 GMC 2500HD EC/SB 6.6 LBZ allison 6 speed, 4" MPRP turbo back, QS2 on the 70HP tune
2000 chevy2500 RCLB 6.0
4L80E,4.10s,aem intake,180 t stat,ported tb,descreened maf, true duals with high flow cats and 40s dumped, lt285/75r16 MTs,an a hypertech programer for now saving for a custom tune now its dead
15.9 at 88 with mudd tires
1973 chevy k10
1989 chevy k1500 stepside
a 305/700r4/208, 38 Tsl's, around 4 or 5 inch lift
That things got some flex
That thing is beautiful. What are some of the advantages of flipping your leaf springs around?
Chris
Nice rig, man that thing has got some flex!
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
those springs aren't supposed to be upside down.... (don't think)
that's due to flex/old springs
yup that rear spring isn't supposed to do that, yes they are a old set of springs with 2 leafs taken out and the over load turned up side down but its all in trying to get it to crawl over any rock or anything else that gets in the way.
The rear springs are the factory rears out of a 74 chevy c10, the rear suspension is made up of a shackle flip(moves the shackle over the spring instead of under it, which gives ya about 4inches of lift and a heck of a whole lat better flex) with a 6in long shackle, factory 56 in long springs and a zero rate(looks like a lift block but bolts on to the leaf pack by the center pin and has holes drilled in it so you can move the axle 1in or 1.5in or leave it centered).
The front suspension is a home made front spring hanger that is moved forward 2 or 3inches and down 2inches so I can run factory rear springs. The front springs where the original rear springs on my truck and I am also running a 6inch long shackle.
