Results 1 to 4 of 4
Thread: Turbonetics T76 - BallBearing-Strim-.81
    San Antonio, TX
    Here is a brand new, never used, turbocharger for anyone looking to upgrade to a bigger, better turbocharger.
    This turbo has the same components as the GTK series, but not the fancy cover.
    This turbo will be right at home on any front mount turbo kit that has a stock or modified 4.8/5.3/6.0 engine.
    This turbo will spool up very quickly even on a stock 5.3L and will support the power a modded 6.0L can put out.
    $1200 takes it. Don't wait long, this sale is only valid for a few days, then I'm sending it back to the manufacturer, so regardless, it's gone by mid next week.
    College Station, TX
    that sure is purdy!
    Jun 2007
    whats it run if i was to order one ?i mean what am i saving?
    San Antonio, TX
    Quote Originally Posted by Ramsey View Post
    Depending on who you get it from, a few hundred bucks.
