Results 1 to 6 of 6
Thread: Oil Pump?
    maryland
    Oil Pump?
    looking into getting a new oil pump. should i go with a high flow or just buy another stock on?
    i have heard that the high flow are not good for our engines because they starve the bottom end of oil. is this correct?
    thanks damon
    LQ4 6.0- 224/224-.560/.560-112 cam, long tube headers, flex-a-lite efans, k&n intake, throttle body spacer, msd 8.5's, e3 iridium plugs, and special thanks to Justin at Black Bear.
    4L60E- "The Beast" sun gear, super hold servos, transgo shift kit, pinless accumulater piston, 5 pin planetaries.
    Feb 2009
    Roy, Utah
    Get a ported LS6 pump from Texas Speed, that'll flow plenty.
    99 Silverado 1500 4X4- 6.0 LQ4, LPP headers
    00 Trans Am- H/C LS6 intake, 100 shot
    11.64@121 w/1.74 60' @4400' elevation
    Dec 2008
    get a stock one and port it yourself.
    Cammed Sierra lowered on 22's.
    Pittsburgh, PA
    LS6/6.0 same pump and port yourself!!! had this combo for years with great oil pressure
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    maryland
    ok cool thanks.
    Do you need a new oil pump?
