Results 1 to 9 of 9
Thread: Harland sharp roller rockers
    The Garage
    Unhappy Harland sharp roller rockers
    Just a heads up, I TRIED to install a set of harland sharp roller rockers in my 4.8L and sure enough they didn't fit under the valve covers. That said, I can gaurantee they won't clear in a 5.3L either. To make matters worse, because the roller rockers are so damn big, you can't even use valve cover spacers with them either as the roller rockers sit EXTREMELY close to the top of the cylinder head wall where the lip of the spacer would mate to. The only method of achieving proper clearance would probably be to use aftermarket valve covers which I discovered are expensive. So does anyone know who makes higher ratio (Preferably 1.8:1) roller rockers that WILL fit under factory valve covers?
    Dec 2008
    Del Rio, TX
    Go with the scorpions. They r a direct bolt in kit and they are about 350 bux. Ive heard and read a lot of good things about them also.
    1993 Gmc 02 ls1 Circle D 3400 stall, long tubes, 220/224 cam stage 3 heads, weiand intake, auburn posi, 389rwhp 352ft/lbs
    Pittsburgh, PA
    stockers FTW, good enough for the LS7 good enough for rest of gm motors
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Wasilla, AK
    Crane part number 144759-16. Gold 1.8 ratio rockers, they fit under the stock valve covers without any modification.
    2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
    Dec 2003
    Azle,TX
    1.8 rockers are a good deal for people like me that want a little extra for a little work.....yes,buying them new is not cost effective but picking up a set for 200.00 or less isnt bad and in my case would give me 588 lift versus 535...just my opinion.Are you gonna sell those rockers?....or trade....?
    Vortec Performance Tuned
    The Garage
    already returned the rockers
    The Garage
    curious.....
    will the scorpion rockers trigger the knock sensor? There isn't much info on their website. Crane cams' website said their rockers won't trigger the knock sensor. Any thoughts?
    Mar 2006
    Mesquite
    I ran Harland Sharp's with zero issues.
    Oct 2007
    another here with HS's on a stroker.. they arent as loud as my springs
    02 Sierra... motorless for now.
    02 SS.. stock bottom 4.8, 241's, 224-220/116+4, 918's and pushrods, front mount turbonetics 78mm, HKS GTII, TiAL, eBoost2, Yank PT3600, Performabuilt 60e, solid motor mounts. Tuned by me with HP Pro and LM2/AFX
