Results 1 to 10 of 18
Thread: Cam suggestions
    Round Rock, Texas
    Cam suggestions
    I've got a '04 ECSB 5.3L with ~48,000 miles. I'm not going to be racing. Mainly a DD with occasional heavy towing. I just want more torque! I rarely see a 5000+ pull. I want something that will keep the mileage up and give more power. I've got the G80 with 3.42s so I might be looking at a posi or trutrac(recommendations??) Since I'm leaning more towards torque, will the stock converter and tranny be fine, or should I beef it up? Comp recommended a 54-408-11 which is a 206/212. Click! Also looking at this valvetrain upgrade kit. Do I need a new timing chain? Valve locks? Valve seals?
    EDIT: I have a K&N CAI and flows catback. Headers are in the budget, too.
    Round Rock, Texas
    Bump!
    Check out the 080 cam in the link below. It should fit your requirements. Your stock tranny should be OK if you don't beat on it too hard. Your stock converter will work OK, but you would be happier with something like a Yank TT2600. Something with a heavy-duty clutch for when you tow.
    LS TRUCK CAMSHAFT
    Crossett,Ar
    I run a cam called the OLD man cam by Thunder Racing. For a off the shelf torquey cam its not that bad. I ran it for MONTHS without a stall and was fine. And its a bit bigger then the ones listed so far.
    Oct 2007
    yea its got a crap ton of lift.. TR makes a good cam. i'd say a 216/218 .580/585 115 or 116
    02 Sierra... motorless for now.
    02 SS.. stock bottom 4.8, 241's, 224-220/116+4, 918's and pushrods, front mount turbonetics 78mm, HKS GTII, TiAL, eBoost2, Yank PT3600, Performabuilt 60e, solid motor mounts. Tuned by me with HP Pro and LM2/AFX
    Round Rock, Texas
    Will that cam still get decent mileage? I know when I'm pulling a fully loaded 5000+ lb trailer I won't care, but when I'm unloaded I want something that sips the gas not chugging it like my '73 F100, 6 MPG loaded or unloaded FTW!
    Crossett,Ar
    I average around 19 or 20... is that good?
    I'd say so. ^^
    Round Rock, Texas
    19-20 on highway is about what I get now. What about city?
    Crossett,Ar
    Same... But I have 4.10 gears. So that helps in town alot
