Results 1 to 10 of 13
Thread: possible trans issue...
    Southeastern Wisconsin
    So i have the truck completely back to stock . Anyways economy is sucking as everyone knows, i got laid off about a month ago, and i need to just drive the truck for another month or so till i can look at gettin a newer one. So trans seems to drive fine, until you are just crusing and its in O/D and you just barely give it gas and it seems to jerk around and make the truck jump a bunch of times, if you step on it a decent amount it doesnt do it at all.
    Anyone got any suggestions?
    I will check the trans fluid and such tomorrow in the daylight, but it was bright red, just changed about 10k ago and didnt smell burnt at all.
    Thanks, Andy.
    1999 GMC Sierra SLE ECSB .... 5.3L w/ Slight Performance Tune / True Duals with Flo Pro Glass Packs.
    Project ''Bad Company'' Future = 6.0L (Forged Internals) / Boost (TVS) / 4L65E LvL 5 / AWD Conversion / Full LT's with Cats / Methanol Injection / Lowered 2" / SS Rims / Frame Up resto
    Officially Employed!!!
    does it make any weird noise when you do that. like almost grinding or no.
    Put a slight amount of pressure on the brake pedal with your left foot (just enough to keep the cruise from engaging) in a situation where otherwise the problem would occur and see if it still happens.
    ok i will try it nathan, it didnt seem to do it tonight on the freeway at all under cruise control, who knows whats going down. And no noises. it just feels like the truck is going over bumps when it happens.
    San Marcos Texas
    Ya Like Nathan says to try, it might be the lockup clutch.
    well went out today and couldnt get it to do it all day so i dont know, i will drive around some more this weekend and see what happens.
    This wont hurt anything right now will it?
    San Marcos Texas
    If it is working right then ok drive it around!
    So drove it for nearly 3 days and nothing would go wrong, and then today it did it again. Only after a little while of driving though, and this time it wasn't as violent but more smaller faster jerking. And pushing on the brake pedal didnt seem to change everything, and its definately only in OD because after it happened i put it in 3 and drove around town just fine. Trans fluid is bright red and inbetween where it should be on the stick.
    So 4th gear is going away 'cause the brake input should turn off the TCC and the TCC applies in M3 as well...
    crappy then.... this is only got less than 30k miles on it, and so does the TC. oh well time to get a new truck.
