Results 1 to 10 of 18
Thread: Dropping my truck
    Jun 2004
    pasadena, tx.
    Where s the best place to get my truck dropped as far as expence adn quality work. I was thinking of a 3/5 on my 04 single cab. Id prefer south/east side of houston but anywhere in houston is cool.
    04 4.8 FIPK, Pacesetter long tubes, dual exhaust with x-pipe and Dynomax race bullits, gutted cats, 160 therm, hypercrap programmer
    Future mods-p/p thottle body, 02 z06 cam, within the mth. 4:11 g80 soon after......just tryin to blow my tranny
    Jun 2004
    Pearland
    I want to know the same thing. I plan to put a 2-4 on my extended cab pretty soon.
    Jun 2004
    West side of Houston, Spring Branch
    You may want to try 4 wheel drive parts. They have done work for me and have done a good job. They only screwed up one thing (put the wrong headers on) and they repaired everything at no cost to me.
    2005 ECSB 5.3
    Mar 2004
    Wheaton IL - Chicago
    Do it yourself ?
    Not to hard if you havent done one before
    or have a buddy help you.
    You can drop one in 5-6 hours
    The have it aligned
    2003 LS 2wd ECSB 5.3 3.42 locking,
    D&J Intake, 180F T-stat, Gibson Sport Truck system-replaced muffler w/ Race Truck muffler,
    TB Bypass, ASP pulley, B&M 24k SuperCooler, Nelson Tune.
    Hotchkis 2"/4" - IAS Rear Shocks
    6,700 miles
    AIM = Buyer Beware !!
    http://members.cardomain.com/csherma1
    Jun 2004
    pasadena, tx.
    WELL ILL BE MORE HTTHN GLD TO LET U HELP........SORRY MY KEY BORD IS MESSED UP
    Mar 2004
    If you are close
    I would let a hand........
    Your buying frosty beverages...
    6,700 miles
    Aug 2003
    Spring, TX
    What tools are needed to install a 2/4 drop on a truck? My drop kit consists of spindles, hangers and shackles.
    -leo-
    2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
    01 silverado ecsb - (RIP 04/2009)
    Jan 2004
    These items/tools will help a lot...
    -Codder pins (to replace the stock ones you'll remove during spindle change)
    -Spring compressor (keep tension on front springs while you change spindle)
    -Grease and or bearing packer to regrease all wheel bearings
    -Good variety of wrenches and sockets...torque wrench is nice
    -Big friggin hammer...pickle fork is cool too but be careful w/ the ball joint boots
    -Floor jack and jack stands.
    -Probably forgot something but that's all I got now...lol
    The hardest part will be the hanger swap....not fun since you'll have to remove all the stock rivets to bolt in the new hangers. A grinder will work, drill, or air tools...specifically air chisel.
    Did you get McGaughy's spindles or BellTech?
    Cameron
    Mar 2004
    Shackles are the easy one
    Floor jack and hand wrenches
    The hangers are PIA
    Grinder for the rivets or plamsa or torch - drilling them out takes weeks (j/k)
    Grind the head off and take a punch and punch the body of the rivet thru
    make sure you have the truck and the rear end supported.
    The tank will have to be lowered and moved inward.
    Once you get the rivets out - they are easy
    Spindles
    Hand tools.
    Floor jack - 3 ton
    I use a ball joint tool and a tie rod tool
    breaks them free vs a pickle fork or banging on them
    Check www.goodtool-online.com
    Spindles take about 45 min to 1 hour per side
    Shackles 30 to 45 mins
    Hangers - depends on what you plan to remove the rivets with.
    6,700 miles
    Aug 2003
    Spring, TX
    Thanks for the list and time estimates guys!
    Physh1, i bought the McGaughy's because I heard that the Belltech spindles reduce the turning radius.
    -leo-
