Results 1 to 7 of 7
Thread: heads, help please..
    Feb 2008
    Arizona
    I'm about to swap the cam, and a friend have a set of 317's that he is selling me, will they improve performance over my stock ones?? I don't even know which ones I have.. I will port and polish either mines or the 317's..
    thanks!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    317's are for 6.0's.
    Feb 2008
    Arizona
    yeah I know, the guy said they fit my 5.3L.. I'm wondering if they would increase performance over my stock ones
    Spring, Texas
    317's will lower the compression and allow for more boost. So, ya in a way it will increase performance especially with a little P&P.
    Feb 2008
    Arizona
    is that improvement worth $300??
    Spring, Texas
    Quote Originally Posted by Felix Arrizon View Post
    Is that just for the heads? Then add for the p&p? Typically for any FI, the 317's are a good inexpensive mod to make. I was thinking about getting some as well. You can find them for around $250 with rockers and springs quite often.
    Feb 2008
    Arizona
    just heads and springs bud.. I'll try to work the price down.. I already have a new set of springs to trow at them..
