Results 1 to 9 of 9
Thread: 160* Thermostat
    Bakersville, NC
    160* Thermostat
    Installed one today and now the truck runs 10 to 20 degrees cooler but also runs 10 to 20 degrees warmer. Anyone else had this problem?
    David,
    2003 GMC Sierra Denali, LQ4, AWD, AWS, 4.10, Wheatley 93 tune, LT headers, GMPP CAI, BBK 80mm TB, MSD wires, E3 plugs, 160* T-stat, Flowmonster DI/DO, cutouts. Working on 4.8 heads, just purchased Comp 228R cam, 918 Springs, TI retainers, 7.4 hardend pushrods,
    Quote Originally Posted by SIERRA SS View Post
    Huh?
    It runs 20 degrees cooler and warmer? I put a 160 in mine a few weeks ago and it's been a hassle....doesn't stay warm enough...gives me P0128 once and a while. Wish 180's were easier to find at a good price for the newer 05+ style water pump...
    Bakersville, NC
    Warmer than the stock t-stat.
    David,
    Birmingham, AL
    but how does it run cooler AND warmer??
    01 Silverado
    Not sure.
    Birmingham, AL
    maybe before it goes into the radiator its warmer then once it goes thru it its colder...
    01 Silverado
    Bakersville, NC
    What else can i tell you With the stock t-stat the guage never got above 210. Now with the 160* it runs about 190* to 200* but has climbed up to 225* to 230*. I'll try purging the system again tomorow might still have a air pocket in it.
    David,
    You do. Not sure what the cooler part was in your post though. I have efans but since my tstat install it never gets above 175.
    P'cola Fl
    +1, yup done a many flushes on these trucks they can be a pain some times to the air pockets out
    03' sierra Z71 slt ecsb 5.3 throttle body coolant bypass, k&n complete intake kit, descreened mass airflow, dynatech long tube headers into dynatech high flow cats with y pipe into magnaflow split duals out the back.
    "I call her trish" ..... cause something this sexy and devious has got to be bad for your health....
