This kit has been reduced and I will give a NEW 62mm turbo with it. I need this set up to go so I can start on the next build
We are about to start a new build with our test truck and this kit need to find a home. Complete kit is for sale. 4400.00.
This set up would normally cost 5700.00.
Kit has been running on our truck for less then 1 year.
Kit comes complete with
standard INTRO kit. 62mm turbo with .81a/r
Stainless steel hot pipes,
Aluminum cold piping
Silicone couplers clamps
Oil pressure line and return lines.
Custom water to air intercooler, prototype heat exchanger, water tank* pump hoses everything.
new air filter will be sent with this kit..
Drop a pm if you would like any other data about the kit.
*water tank is our standard tank.
here is some pics of the set up.
Intercooler pump is Mounted under the water tank. Air lid is not included in the kits sale price.
Intercooler is mount to the altenator main bracket. 50mm blowoff inlcuded.
Custom intercooler mounted on the drivers side.
Custom heat exchanger build from a radiator to fit the area behind the grill with no modification to the grill or core support. Inlcudes all the hoses needed for the install.
