will this work on my 2000 silverado 2500 or does it only work on the 1500
What are you trying to do?
If you use a 1500 key on a 2500, you can get lift. 2500 key on a 1500, and you get drop.
Gone, but not forgotten!
just level the truck out to fit 285/75r16 and get good stance without spending alot of money any other ideas
I would do the 1500 keys.
will it mess with how much wight i can put in the truck
You can put ford keys in a 2500. My friend has them in his cranked up 2" with aftermarket shocks and it rides fine.
I have a set of 1998 Chevy S10 4x4 keys that have never been installed sitting in my garage. If you think they would work, shoot me an offer and Ill ship them out. These were originally going to lower the truck, but you might be able to flip them.
2007 Chevy Silverado Classic 4.3L V6
Magnaflow Muffler, CFM Technologies CNC Machined High Flow Vortec Throttle Blades, STS Rear Turbo, Intercooler, Accell Distributor and Coil, 8mm wire, Autolite Platinum plugs, Runs out of fuel at 4000RPM. Marine intake with larger injectors soon. Hoping to squeeze 10psi.
any one know if s10 torsion keys will work
Ill take a picture of them and post them when I get to the house around 5PM
ok sounds good
