Results 1 to 7 of 7
Thread: Anybody else here have a 99?
    Anybody here have a 99 that was plagued with false knock? Im running a 2002 PCM now since my 99 was so bad. Did you have it updated and did it solve the problems? I cant use Edit with this 2002 PCM, I need my 99 back and running!
    -Jared
    Jun 2003
    I too have a 99 GMC with a LS1 that suffers from false knock.
    Others have used resistors to de-sensitize the knock sensors.
    I plan on getting the harness that runs from the back of the throttle body where the knock sensors connect to the computer. Then cut the wiring so you can solder a 10K ohm resistor for each sensor wire between the 2 connectors, thus making an inline resistor jumper. I hope this will plug between the back of the throttle body and the computer eliminating the false knock. By making it a plug in jumper you can remove it and adjust the resistors if you still have knock after checking with a diagnotic scanner.
    I have not done this yet due to lack of time, always working.
    ts99
    99 GMC, ECSB w/ LS1 from 99 TA
    E-fans, 3:73, Eaton posi
    Wow. An LS1 truck website and nobody has any isnight on this.
    -Jared
    Dec 2003
    GO TO LS1TECH.COM
    2000 Chevy Silverado 2500 ECLB w/6.0 , 4L80E auto, 4.10 G80, K&N, Nelson Dyno Tune, 02 PCM STS TURBO , 44# injectors, IC ,HPTuner and 160* thermo 348 rwhp, 394 rwtq @ 5 psi
    60'=2.241
    1/8=9.352@77.39
    1/4=14.40@ 96.67
    San Marcos Texas
    I don't think too many on this site have '99s.
    May 2004
    I have a 99 but I don't think I have a problem w/ false knock.
    13.920 @ 98.94mph...[/b]
    Originally posted by jerry2500@Jul 1 2004, 04:52 AM
    GO TO LS1TECH.COM
    Gee thanks man. Found that site 2 years ago.
    I just wanted to see if anybody else has had problems with their 99 PCM's. I think its time to get rid of my truck.
    -Jared
