Results 1 to 10 of 15
Thread: How much TM removal?
    San Antonio, Tx
    I am finally getting tuned at the end of the month, how much TM does allen usually remove? I was thinking of 80% and I also read to remove all of it at WOT. Does this sound okay for a stock tranny? Oh, and what should I set the shift firmness at for a daily driver?
    02' 5.3 ECSB| Nelson 93 Tune | 212/218 Cam | Circle D 3200 | LPP lt's w/ ORY | Volant CAI | Magnaflow | Raceready Cutout | Belltech 2/4 | JL Audio |
    Okeechobee, Fl
    Get youself some vette servos to throw in your tranny and have him make it as bad as he can!! Either way the 60E is gonna blow, so why not speed up the process! I'm sure others will chime in and help you better than I can. Just giving my .02
    49 Ford F1
    Remove all of it and the trans will go first then when you get a beefed up trans or put vette servos in the rear end will explode. Me I'd remove all of it and replace the trans see the 4l80 post on the front page. Then replace the rear end. Then add a huge turbo then when you scatter the motor and need another buy an LSX454 and get another turbo since metal from the scattered engine killed the original. Then buy some brakes you'll need them.
    San Marcos Texas
    I would take it all out and have some fun with the 4L60E until it is spent. If you do add the servos and shift kit it might make it last a little longer.
    Make it -6 million. That will make it shift hard.
    Birmingham, AL
    does it really make that much of a difference??
    say you had 100% TM then took it all out how much would u gain in the 0-60 or 1/4 mile?
    01 Silverado
    San Antonio, Tx
    Looks like the tune is cost more than I thought... new tranny, rear end, AND an engine!
    NOO a tune is worth every penny. My trans lasted a long time supercharged and me abusing the crap out of it.
    My rearend blew once I got an FLT level 5 tranny. Get rid of all the torq management and you will be ok for a while but if you build lots of power then parts start breaking. All of this has been with zero trq mgmt and once it is gone you will love your truck even more.
    San Antonio, Tx
    Yea I'm definetly looking forward to the extra power, from what I have read its a night and day difference.
    newburgh, NY
    What about when you up the pressures will that help the trans last a little longer?
