Results 1 to 10 of 10
Thread: 4.8 Cam
    Dec 2008
    Kentucky
    4.8 Cam
    ok...so what would be the best cam for the 4.8? Besides the cam what else am I lookin to change for about $200-$350 for a noticable gain in HP? I'm an electrical guy, I know how it works and what it consist of but I have never turned a tap on a motor...besides electrical stuff
    2001 GMC Sierra 4.8
    lowerd 2in in rear
    custom cat-back
    and the ever so mighty K&N
    -"Faster, Faster until the thrill of speed overcomes the fear of death."
    -Load it like a Freight Car
    -Polish it like a Show car
    -Drive it like a NASCAR
    S.A. Texas
    if your planning on stay NA i would go with a .220/.220 .581/.581 112lsa with a circle D reworked TB stall. Might need a 3200 stall. When you do the cam you need to go ahead and vale springs, and pushrods. Might as well while you are in there.
    Found my cam used for 250, Valve train upgrade was 430 and the stall is about 350 and before or at the same time as this you need a tune from Nelson Performance!
    HOUSTON
    i got a buddy with that cam and he's pretty happy with it
    6.0 is done, arp everything and a cam 13.83's. 02 ecsb no other bolt ons.
    College Station, TX
    Is the Truck your daily driver?
    Dec 2008
    Kentucky
    Quote Originally Posted by Aggie View Post
    yep...it is for now anyways
    2001 GMC Sierra 4.8
    lowerd 2in in rear
    custom cat-back
    Malvern, AR
    will that cam work with a factory stall?
    99 GMC 5.3 RCSS, K&N, E-Fans, Headman Shorties, Built 4L60E, 220/220 .581/.581 112, 80mmm TB, Nelson Tuned
    S.A. Texas
    it would work alot better with a stall, you might loose some low end without one
    Okeechobee, Fl
    ^^^+1^^^
    49 Ford F1
    Jul 2007
    Colleyville, Tx
    220 range sounds good... I would invest in some gears like 3.73 or 4.10s and a stall first.
    Dec 2008
    Kentucky
    yep...I think factory I have 3.42 gears...I think...
    2001 GMC Sierra 4.8
    lowerd 2in in rear
    custom cat-back
