oil pressure high?
when ever i step on the gas the oil pressure rises too and berfore it didnt do that can somebody help?
That's normal. When you first start the truck it will prob be around 60 or 70 as it warms up and the oil flows easier, it can be anywhere from 20-50. As RPM's increase so will oil pressure. Is it doing something different than that?
- You may not post replies
- You may not edit your posts
