Power Mirrors
ok
xmas morning I go to leave, pull out of the garage, push the button to have the power mirrror fold out when they dont move back up into proper location.
Ive had that before, no biggie. I reach down to press the button to move them to where I need them and they dont respond to the controls..
they fold, and if i manually put them in place, and fold them in, they will move downward (talking about the glass), but they dont move back up ward when they unfold.
anyone know which fuse I should check, or have a part number for the control switch in case i need to just order a new switch?
I'm confused on what it's doing wrong. What year? You have the mirrors (including three motors and position sensors in each one), driver's door module, memory seat module, mirror switch, and all the wiring. Post a video or something. Most times something like this requires GM service information, a Tech2, and electrical test equipment to diagnose.
Solved!
i took the negative off the battery terminal.. (thanks Mike) for a while, and while doing it, I noticed I blew the fuse on the Efans, and burned 2 connectors on one of the relays. I just went to autozone in the BonjStang and got new connectors and fuses and fixed it up.. all works perfect again.
It was pouring rain in St. John's and I was stuck inside with nothing to do. I saw an ad on social media pointing to https://playjonny.ca and figured, why not? I only had a few dollars to spare for entertainment. I used it on slots online and triggered a free spins feature that went on forever. By the time it finished, I had enough to buy a new gaming headset. The online casino bets poker options are great too, but the reels are where the real luck was for me that day.
Hey, ik zat laatst ook binnen door slecht weer en zocht iets om de tijd door te komen. Toen kwam ik toevallig trueluck tegen, en wat me meteen trok was dat ze speciale bonussen hebben voor spelers uit de Nederlanden. Ik besloot het spel Gonzo’s Quest eens te proberen; eerst verloor ik een paar rondes achter elkaar, maar daarna kwam er ineens een flinke winst uit, wat echt een opluchting was na al die eerdere teleurstellingen. Sindsdien speel ik er regelmatig en het is een leuke manier om even te ontspannen en wat plezier te hebben.
- You may not post replies
- You may not edit your posts
