Results 1 to 8 of 8
Thread: News guys build...
    News guys build...
    I'm new here and all but maby this build will help someone out...
    I have finaly collected most of the parts I needed to start the SAS on my 92 ECSB Chevy. When the truck is complete. I'll have 79 HP D60 Front W/ a Detroit Locker, Hydro assist, and 4,56s. The rear Is a D70 3HD 10 1/2 Ring gear, with 4.56s, Detroit Locker. The front will have a total lift of 9"s the rear will have a total of 8" of lift. I going to have the rocker panels Line Xed along with the bed. Also toward the end of this year I'll be saving up for a 6.0L.
    The build is now complete, this is the list of stuff I used... There is a few thing i likly forgot to list but I'll ad them as i remember!
    78 dana 60 kingpin front.
    87 dana 70 rear.
    ORU SAS kit +6" in spring length.
    16x10 Procomp Rockcrushers.
    Kingpin rebuild kit.
    New pads/ shoes for the brakes.
    new ujoints for the axle shafts.
    37x13.50 mickey thompson Baja Claws.
    4.56s Front & Rear.
    Detriot lockers F/R.
    Hydro steering stuff.
    Draglink.
    Steering arm.
    Tie rods.
    Brake lines.
    Hub Bearings.
    Ubots and Ubolt plates.
    Ujoint rear axle.
    Front driveline.
    Bilsten 7100 shocks.
    BTW the stock gears and carriers out of the front and rear axles need to go. The D60 front has/had 4.10. The D70 Rear has/had 3.73s.
    The rims
    The rear d70
    The front d60
    Finaly got the springs, and know I just need to finish mounting them...
    I still need to mod the exhaust a little...
    Well this is where she sits as of right now, althought not pictured. I do have the front spring mounted on one side of the hanger.
    I teased myself with this pic...
    1992 ECSB SFA K1500: D60 Front, D70 Rear, Hydro assist. 9"s of lift sittin' on 37"s
    1997 RCSB K1500: CAI, Exhaust, Tune. Headed to the trans shop!
    1999 2dr Tahoe: 4" Rancho Lift, 4.56s W/ True-trac.
    I'm useing an old spring pack and jack to lift the springs to mount them
    Here is the ram
    I have to fab up some new mounts for the rear bumper
    They choped off the rear frame mount :teddy:
    The PS Gear Box Started to leak :teddy:
    Random tire pile
    The drag link
    The Lines for the ram were getting hit by the Pitman arm so I have to change the fittings on them
    The rear is fully mounted, the front still needs alittle work
    Much better with the front bumper on, I'm going to a friends shop to weld the mounts on the bumper tonight.
    Some updates on the truck... shes 100% complete now!
    My new favorite Pic of the Chevy!
    If you have any questions ask away!
    Well a little update on the FNGs truck: I no longer like the Cali lean so I'm going to switch out the leafs, and I have a long list of stuff I broke on my last wheeling trip... So I'll post those pics as I go!
