Here's my solution to the A/C mounting in my 93 C1500. The only changes made to the 6.0L was to remove the ridges from the tensioner and turn the water neck. The bracket I used was an extra one from an earlier TPI swap I had done.
If I measured it correctly, I will need a 110" belt.
