Results 1 to 2 of 2
Thread: Extra OBD II or Can bus Wire From PCM
    I am in the process of simplifying my harness and noticed the extra can bus wire that goes to the original 02 Silverado gauges will not be used in my 1985 Silverado. I was wandering if it is the same signal that goes into the OBD II diagnostic connector? My reasoning is I have HP Tuners and i also wanted to use the PLX OBD II gauge but each requires the diagnostic connector could i split the original connector or simply use the Data wire that fed the 02 gauge cluster.
    1985 Silverado LQ4/4l80e Turbonetics Single Turbo, 60lbs injectors, air to water intercooler, PST driveshaft, ARP head & rod fasteners, Custom cam, HP Tuners, PLX wideband, DUAL tanks still work!
    San Antonio, TX
    You'll have to split the one wire going to the obd2
