Results 1 to 9 of 9
Thread: Rear diff fluid Truetrac ?
    Okeechobee, Fl
    Question Rear diff fluid Truetrac ?
    I'm installing my gears and truetrac next weekend and need to know what fluid, how much and also if I need the bottle of gm additive?
    Thanx in advance!
    49 Ford F1
    Slimsilverado Guest
    3 quarts of Mobile 1 gear oil, synthetic, no additive needed, Tru trac has gears in it not clutches...
    wichita falls, tx
    +1 on the no additive...no clutches in the tru trac = no need for limited slip additive
    Intro Radicalli's
    .....no add I'm in on but might also think about the $27 per quart GM synth too....
    Okeechobee, Fl
    I thought with the truetrac you're not supposed to use synthetic, but then again that's why I asked. Thanx guyz!
    Also is there a certain weight oil I'm supposed to use or just any mobile 1 synthetic gear will work?
    GasGuzzler I wish I could afford that but I already had to borrow money from my Dad for the truetrac.
    49 Ford F1
    Mar 2007
    Newark, Delaware
    From what i've read on PT.net (and on this forum too... i think) you are not supposed to use synthetic.
    Mar 2007
    Newark, Delaware
    Okeechobee, Fl
    I called Detroit today and he said "DO NOT USE SYNTHETIC!!! It will cause the gears to slip."
    49 Ford F1
    Oct 2007
    Bandera, TX
    i run royal purple....lol... oh well
    single digit street truck
    for build info
