Results 1 to 10 of 33
Thread: Converter On the Fritz??
    Spring, Texas
    Question Converter On the Fritz??
    So here's the deal. When I'm just cruising, it shifts fine, acts normal and sounds normal, but when I start to get into boost and get to about 4-6psi, it's like the trans goes to neutral. Boost keeps building but I don't accelerate. Plus, I can feel like a grinding in the trans. If I back off the gas and just accelerate normally, it works just fine. Any ideas??
    What gear?
    Nov 2006
    Mesquite, TX
    check the fluid, see if its burnt, also im with nathan what gear does it do this in?
    Spring, Texas
    Fluid still red not sure what it's supposed to smell like. Typically it's in 2nd gear when this happens.
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by ramair2002 View Post
    your 2nd gear band is slipping, i had this happen also, time to replace it before you loose 2nd all the way...if the fluid was burnt it would smell like bad and be purplish to black color
    Probably not the converter as it would affect all gears. Could be the band, forward clucthes, an internal oil leak, servo piston seal, low line pressure or the forward sprag start to come apart (common failure on 04+ in stock form). Not sure what type of sprag FLT uses.
    Spring, Texas
    How major is that sort of operation?
    Remove the trans and pull the pump and input housing to replace band and/or sprag.
    Nov 2006
    Mesquite, TX
    hell didnt notice you have an FLT trans, just holler at them boys they will tell ya whats wrong with it and take care of you on it
    Spring, Texas
    Thanks!
