Results 1 to 10 of 15
Thread: speed limiter
    Birmingham, AL
    speed limiter
    would Allen automatically remove my speed limiter?
    i was just thinking about it and since i got my PCM back from him its still at 98.
    01 Silverado
    Spring, Texas
    Normally he disables it whenever you get a tune even if you don't ask.
    Prolly not.
    Birmingham, AL
    i didn't specifically ask for it to be disabled, i don't think. just making sure i actually got a tuned computer and nothing went wrong somewhere during the whole process
    01 Silverado
    if you ordered a tune, it would be set accordingly!!
    Simple: 408 on steroids!
    single digits coming soon!
    Pittsburgh, PA
    no limiter is disabled its just raised higher. mine is set at 255mph
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    ff_jeff Guest
    Yeah cause you might actually go that fast one day. I dont know what mine is at, but I have run out of speedo. And Not to thread jack, but can you tune the tranny to shift into OD while at WOT?
    Pittsburgh, PA
    unless the trans is built i wouldnt run in OD. the stock parts arent meant to handle the load in OD
    412 Motorsports
    ff_jeff Guest
    So when I get to the top of 3rd... what do I do? just coast through the traps?
    Pittsburgh, PA
    raise rpm limter
    412 Motorsports
