We hope you find the historical data for your vehicle to be both informative and helpful. Make sure to print a full report for your records. Also, please keep a copy of this email as it will provide you the following information about your order. Thank you for visiting www.autocheck.com!
Your return Login ID is:
Your Vehicle's Description:
VIN: 1G2NF52E12C292841
Year: 2002
Make: Pontiac
Model: Grand Am SE
Style/Body: 4 Door Sedan
Engine: 3.4L V6 MPI HO
Country of Assembly: United States
Key: = No Problem Found = Problem Found = Information Found
Your Vehicle Checks Out! AutoCheck’s results for this 2002 Pontiac Grand Am SE(1G2NF52E12C292841) show no significant Title events. When found, events often indicate past automotive damage or warnings associated with the vehicle title.
Problems Checked: Results Found
Abandoned No Abandoned Record Found
Damaged No Damaged Record Found
Fire Damage No Fire Damage Record Found
Grey Market No Grey Market Record Found
Hail Damage No Hail Damage Record Found
Insurance Loss No Insurance Loss Record Found
Junk No Junk Record Found
Rebuilt/Rebuildable No Rebuilt/Rebuildable Record Found
Salvage No Salvage Record Found
Your Vehicle Checks Out! AutoCheck’s database for this 2002 Pontiac Grand Am SE(1G2NF52E12C292841) shows no historical events that indicate a significant automotive problem. These problems can indicate previous car damage, theft, or other significant problem.
NHTSA Crash Test Vehicle No NHTSA Crash Test Vehicle Record Found
Frame Damage No Frame Damage Record Found
Major Damage Incident No Major Damage Incident Record Found
Manufacturer Buyback/Lemon No Manufacturer Buyback/Lemon Record Found
Odometer Problem No Odometer Problem Record Found
Recycled No Recycled Record Found
Salvage Auction No Salvage Auction Record Found
Water Damage No Water Damage Record Found
Your Vehicle Checks Out! For this 2002 Pontiac Grand Am SE(1G2NF52E12C292841)no indication of an odometer rollback or tampering was found. We determine odometer rollbacks by searching for records that indicate odometer reading that are less than a previously reported value. Other odometer events can report events of tampering, or possible odometer breakage.
Report Run Date: 06/02/2004
Date Reported Odometer Reading
05/16/02 4
01/26/04 36,391
Information Found! AutoCheck found additional information on this vehicle. These records will provide you with more past history for this 2002 Pontiac Grand Am SE(1G2NF52E12C292841).
Accident Data No accident data available
Corrected Title No Corrected Title Record Found
Driver Education No Driver Education Record Found
Duplicate Title No Duplicate Title Record Found
Emission/Safety Inspection No Emission/Safety Inspection Record Found
Fire Damage Incident No Fire Damage Incident Record Found
Lease No Lease Record Found
Lien Lien Record(s) Found
Livery Use No Livery Use Record Found
Government Use No Government Use Record Found
Police Use No Police Use Record Found
Rental/Fleet Rental/Fleet Record(s) Found
Repossessed No Repossessed Record Found
Taxi Use No Taxi Use Record Found
Theft No Theft Record Found
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
VIN 1G2NF52E12C292841 2002 Pontiac Grand Am SE
Event Date Event Location Odometer Reading Data Source Event Detail
05/08/02 SAN ANTONIO, TX MOTOR VEHICLE DEPT. REGISTRATION EVENT/RENEWAL
TITLED OR REGISTERED AS A FLEET/RENTAL VEHICLE
05/16/02 SAN ANTONIO, TX 4 MOTOR VEHICLE DEPT. TITLE (Title #: 01501837382103434)
05/01/03 SAN ANTONIO, TX MOTOR VEHICLE DEPT. REGISTRATION EVENT/RENEWAL
05/01/03 SAN ANTONIO, TX MOTOR VEHICLE DEPT. TITLED OR REGISTERED AS A FLEET/RENTAL VEHICLE
01/26/04 SAN ANTONIO, TX 36,391 MOTOR VEHICLE DEPT. TITLE (Lien Reported) (Title #: 01535237999091111)
New/Used/Refinance Loans for Less Check Your Credit - It's Fast and Free! Save on auto insurance from Esurance
Experian's Privacy Statement
AutoCheck Vehicle History Report Disclaimer:
Experian's AutoCheck Vehicle History Report is compiled from multiple sources. It is not always possible for Experian to obtain complete discrepancy information on all vehicles, therefore, there may be other title brands, odometer readings or discrepancies that apply to this vehicle that are not reflected on this report. Experian searches data from additional sources where possible but all discrepancies may not be reflected on the AutoCheck Vehicle History Report.
THESE REPORTS ARE BASED ON INFORMATION SUPPLIED TO EXPERIAN BY EXTERNAL SOURCES BELIEVED TO BE RELIABLE BUT NO RESPONSIBILITY IS ASSUMED BY EXPERIAN OR ITS AGENTS FOR ERRORS, INACCURACIES OR OMISSIONS. THE REPORTS ARE PROVIDED STRICTLY ON AN "AS IS WHERE IS" BASIS, AND EXPERIAN FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE REGARDING THIS REPORT.
Experian shall not be liable for any delay or failure to provide an accurate report if and to the extent which such delay or failure is caused by events beyond the reasonable control of Experian including, without limitation, acts of God or public enemies, labor disputes, equipment malfunctions, material or component shortages, supplier failures, embargoes, rationing, acts of local, state or national governments, or public agencies, utility or communication failures or delays, fire, earthquakes, flood, epidemics, riots and strikes.
AutoCheck vehicle history reports are intended for personal use only. Any commercial use, resale and redistribution of AutoCheck vehicle history reports is strictly prohibited and may lead to deactivation of your account and imposition of additional charges for AutoCheck vehicle history reports. AutoCheck vehicle history reports are governed by all the Terms and Conditions of use of the AutoCheck web site.
mostly stock 04 silverado 1500 CC
Gibson Headers and Sport truck Cat Back
5.3L 3.73 Detroit True Trac
165F therm,HpTuner
07 17" Sierra wheels
Dark Grey
